Ga door naar hoofdinhoud
Repair information for the Samsung 55" Smart TV with model number UA55JS8000 or UA55JS8000W.
7 Vragen Bekijk alle
Two red line on the screen
Hi dears,
few days back i found a red line on my Screen which not effect the pixels and appear only in any white background.
The support center they said i need to replace the screen
Is there any solution for that?
help please.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@alitawash those do like a TAB error. That is where the bond between the thin ribbon cable and the panel fails. You can try and apply some pressure right above the lines and see if they then disappear. Of course it is best done with the back of the TV removed. Here is an image to show you the TAB bonds.
There is really no fix for it since it requires a special repair. Sometimes it can be temporarily be resolved by continuing to apply pressure to the bond with some tape etc.
If you can, take some pictures and post those with your question. That way we can see what you see. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
alitawash zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 564
