Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor de eerste generatie Nissan Murano, van modeljaar 2003 tot 2007.
How to change headlights bulb
How to change headlight bulb
Is dit een goede vraag?
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
This should help
https://www.youtube.com/watch?v=8tglvV6S...
Was dit antwoord nuttig?
Score 3
@bexon59 open the front portion of the wheel liner. You should see a white cap with ridges and a tab, open that. Next there should be a silver connector socket with a lighting bolt symbol, pull that off. You should now see the back of the bulb and its clip. Squeeze the clip and pull it back to remove the bulb. This video also not the best, should help you with that.
Score 1
IF you open the hood of your car there should be a big black screw (somtimes plastic) if you unscrew that you can pull you head light out and disconect the wires. Then you can take off the back cover to the headlight and change the bulb.
4 opmerkingen:
its that way in my car
door
@tylor_b you have a Nissan Murano?
door
Hes got an old ford escort or some $@$*. My murano is alot more complicated.
door
You can get to it from the inner fender, removing the front wheel well weather protector.
Voeg je antwoord toe
Verland Laurent zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 33
Altijd: 17,647
