How to change headlights bulb
How to change headlight bulb
Is dit een goede vraag?
This should help
Was dit antwoord nuttig?
@bexon59 open the front portion of the wheel liner. You should see a white cap with ridges and a tab, open that. Next there should be a silver connector socket with a lighting bolt symbol, pull that off. You should now see the back of the bulb and its clip. Squeeze the clip and pull it back to remove the bulb. This video also not the best, should help you with that.
IF you open the hood of your car there should be a big black screw (somtimes plastic) if you unscrew that you can pull you head light out and disconect the wires. Then you can take off the back cover to the headlight and change the bulb.
You can get to it from the inner fender, removing the front wheel well weather protector.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 35
Altijd: 16,837
