Ga door naar hoofdinhoud
Handleidingen voor reparatie en ondersteuning van tapijtreinigers.
57 Vragen Bekijk alle
I need a special tool to get my shark vacuum apart
The fasteners look like an allen head with a pin in the middle. Looks like you would need an allen wrench with a tiny hole drilled in the middle of it. Any ideas what/where I could get a tool like this?
Is dit een goede vraag?
Score 2
10 opmerkingen
Thanks for your help!
door
I see what kind of screws they are all I want to know is why!!!!!
door
How in the world would anyone be able to tell you *why* a company used a given type of fastener? Seriously now...
door
The only reason why companies do that is to prevent the "normal Joe" from opening (and fixing) their devices. Companies have done this for years. It absolutely impedes the Right to Repair and that nonsense has got to be stopped!
door
They don't want you to be able to work on them. So in frustration you'll go buy another one.
door
5 commentaren meer tonen
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
@toolbag it sounds like you are talking about the tamper resistant Allen screws. It is a security feature that is easily circumventeed wit tool kits like like these. you can get those for Torx as well as many other screw heads.
Was dit antwoord nuttig?
Score 8
11 opmerkingen:
yes but how do you find out if u need metric or SAE
door
the product is a shark vacuum
door
torx screws are the type
door
@mcgarry there is no difference. The same Torx drivers are used to drive SAE and metric
door
Unfortunately, at least two of the security screws are in a deep and narrow hole that is impossible to reach with the short bits that are commonly sold.
door
6 commentaren meer tonen
These are the right tools to open a shark vacuum cleaner. Yakamoz 11 Pcs Magnetic T6-T40 Torx Head Screw Driver Bit Set Security Tamper Proof Star 6 Point Screwdriver Drill Bits Tools with 1/4 Inch Hex Shank | 3 Inch Length https://www.amazon.com/dp/B078LXZPZ2/ref...
Score 2
2 opmerkingen:
Can I use any other tool
door
No, it must be this kind only. These tools are made by different manufacturers.
door
I have got the screws out but the unit still seems to be sealed. I gave a new lower hose duct to replace the spilt one but now at a loss as to how to get to it.
4 opmerkingen:
@lazyboy How did you reach the deep sockets? I have the correct bit, but it doesn’t reach.
door
Were you ever able to get into the unit to replace the hose, Ali?
door
There's screws under the two tiny wheels at the front. You need to pop those off to even see them. I love shark vacuums but as far as cleaning them they couldn't make it more difficult.
door
Curt, thank you so much for your answer. I have been looking for this tool and it's been very frustrating. You made it so easy. Including the link on where to get it it's so appreciated. Thank you so so much!!! Rae Lynn
door
Any body know exactly what size tool to take apart? Have tried every size and can't get it apart!!
1 Opmerking:
it must be an issue other than size.
do your bits have a center hole?
are they Torx? Maybe they are Allen bits. THEY MUST BE Torx.
door
Voeg je antwoord toe
Joe Kaplun zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 54
Afgelopen 7 dagen: 356
Afgelopen 30 dagen: 1,597
Altijd: 77,913
