Ga door naar hoofdinhoud
Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487 Vragen Bekijk alle
The initial phone opening technique is not working, adhesive too stron
I am having trouble using the ifixit kit to successfully open the GS6. The adhesive holding the rear glass is not loosening up for me to be able to remove it using the provided suction cup. Any ideas?
Is dit een goede vraag?
3 opmerkingen
are you using a hot air source like a hairdryer etc to heat it
door
Thanks, will definitely try that!
door
Use a playing card.. Get the glass up enough you can get a playing card underneath and use it to break the bond between the glass and glue
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
As Daniel has suggested, I would use a Blow Dryer or a heat gun to heat the back. Heat it up just to the point of it being uncomfortably warm to the touch but not so hot that it burns you.
Was dit antwoord nuttig?
Score 1
Please if you're unsure of doing it with a hair dryer or heat gun DON'T DO IT! iFixit has an awesome tool that works great for this iOpener
iOpener Afbeelding
Product
iOpener
$19.99
Score 1
You need heat. Without heat you will not get it off.
Voeg je antwoord toe
bert486 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 178
