Ga door naar hoofdinhoud
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
Lg g5 Flashes 0% Charge
Hello!
I have a LG g5 and won't start.
Only appears 0% battery.
What is the problem?
photo here : https://imgur.com/a/m2EgA
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I had the same problem, it's either the battery or the battery connector on the motherboard
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
It was a diodes from charger port inside the phone. I was in service and they replaced that diodes. Sorry for my English. Good luck!
door
I fixed the problem by changing the battery connector (not the charging port)
door
Salut, am si eu aceeasi problema, a durat mult sa il repare?
1 Opmerking:
mi-am dat comanda si de baterie, cred ca s ar putea sa fie si de la ea
door
Voeg je antwoord toe
Alin Mihai zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 2,948
