Ga door naar hoofdinhoud
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
20 Vragen Bekijk alle
poor wifi and bluetooth signal after screen replacement
hello,
after a screen replacement with a refurbished one, now i have poor wifi and bluetooth signal on my lg g5. i suspect an antenna issue. someone know what could be the matter?
Is dit een goede vraag?
Score 2
2 opmerkingen
hello, thank you for your kind reply. Do you know where can i find the wifi/BT antenna in the logic board?
door
Hello
I have the same problem, did you find a solution?
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
yup sounds like the antenna. order a replacement and swap it over.. if this doesn't fix it, will most likely be a logic board issue. 90% of all cases on the device is the antenna.
furthermore make sure you reseat the antenna connection.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
8 minutes ago by Gabriele Filoni
door
I had exactly the same issue. Check the antenna cable, it is under the motherboard, one of the connectors was disconnected, in my case and that solved the problem. Probably, when I was replacing the screen I accidentally disconnected the cable.
Score 1
1 Opmerking:
Thank you very much it works!
door
Voeg je antwoord toe
Gabriele Filoni zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,133
