Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
My touch screen doesn't work
I have tried a force reboot but it still doesn't work I need help!!
Is dit een goede vraag?
1 Opmerking
Hi Taza, you have already posted this question a few minutes ago. I would encourage you to delete one of these to keep the Forum uncluttered.
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
sounds like a bad digitizer consider replacing or invest that money towards a newer iphone
Was dit antwoord nuttig?
1 Opmerking:
I have replaced the screen so do you think i need to get another one ?
door
Dit antwoord was oorspronkelijk aan een andere vraag gericht.
Is this after a screen replacement the touch didn't work, or did it just stop working the original screen? If it just stopped working, then you will probably need a screen replacement.
1 Opmerking:
I had replaced the screen because it was cracked
door
Replace the screen.do not try it yourself if you are beginner.iphone 4 screen replacement need some set of skill to replace.
2 opmerkingen:
I have replaced the screen but it doesn't work
door
ok,is there any repair shop near yourplace? if yes ask them to bypass their screen a few to make sure that it is really logicboard problem. sometimes parts we bought are defected/malfunction during shipment.
door
The LCD may be bad. Have you tried a new screen or "tester" screen?
Voeg je antwoord toe
Taza zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 72
