Ga door naar hoofdinhoud
How do you remove screen completely off?
PowerBook G4 Aluminum 12inch 1.33 GHz
I have a powerbook g4 12 inch with a broken lcd screen, now I wanted to know if anyone knows how to remove the screen completely off so that I can then plug a monitor to it?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
There's a monitor port on your machine that you can connect to. For directions on replacing the screen, please go here and identify your Book. There is a number on the back that looks like Axxx. Let us know which one you have and we can direct you: http://www.ifixit.com/Info/ID-your-Mac/2...
Here's how to remove the display: PowerBook G4 Aluminum 12" 1-1.5 GHz Display Replacement
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
Like Mayer said you only need a Mini DVI to DVI adapter or a Mini DVI to VGA adapter, then you can plug in an external monitor. As for removing the display, you can follow this guide.
Score 2
Voeg je antwoord toe
Stranga zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,201
