Ga door naar hoofdinhoud
Repair guides and troubleshooting for the 40in LCD TV with model number LA40R81BD or LA40R81BDX. This television was released in early 2007.
46 Vragen Bekijk alle
I have to reset tv each time I turn it on to get any channels
my tv comes up with a no signal message when i turn it on, i have to to do a total reset to get it to work, all is then fine until i turn it off, then have to to do it all over again next time i turn it on
Is dit een goede vraag?
1 Opmerking
@paulineholt how do you perform the total reset? How long has this been going on and has the TV ever fully functioned? Has anything happened that may have caused this?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@paulineholt, Pauline, If you have setup your TV as per your TV's manual, perhaps some how the TV is set to Demo/shop/store mode, if in this mode will not retain your set up. See links below for instruction on removing demo/store mode. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://support-us.samsung.com/cyber/popu...
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
pauline Holt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 129
