Ga door naar hoofdinhoud
Announced in October 1999.
My iMac is stuck at the loading screen
I recently obtained an imac g3 (slot loading) from my highschool, as they had no use for it and were going to throw it in the dumpster around the back of rhe school. My friend and i started it up ( at school, as the one condition was we had to wipe the hard drive) and wiped the hard drive. I took it home, plugged it in and turned it on. The happy mac chime sounded and it went to the screen where it shows the apple logo and a loading wheel. I have tried all the ways to fix it ( reset the pram, single user mode commands, verbose mode commands, trying to boot in safe mode and going into the boot options) but to no prevail. I think i will need to buy an os disk and boot it off that but first, is there any other way?
Is dit een goede vraag?
1 Opmerking
what method did you use to erase the hard drive? Disk or open firmware?
Also, what OS did you install on the machine? as the earlier models have more OS restrictions to later models, and the ram spec makes a big difference, especially if you are trying to get a later OS on it, such as 10.4.
Can you confirm the exact spec of the machine you're dealing with as well? as there are 4 ranges with the M5521 family number.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
There is usually a plate inside the port door on the side of the machine that will tell you which machine you have. Here are 13 different ones: http://www.everymac.com/ultimate-mac-loo...
Select which one you have to see what the original operating system was and just how high it can go.
The school may still have the original installations disks. If not, you will be able to find them on eBay.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Memphis Hancock zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 676
