Ga door naar hoofdinhoud
Een draagbare all-in-one desktop met touch screen, gefabriceerd in 2013 door Dell. Het modelnummer W01A is te vinden door op de rechtersteunvoet van het apparaat te kijken.
My display setting somehow got changed
I came back to my computer which was just in sleep mode, and the picture is not full screen. There is about two inches on each side that are not used and I can't figure out what I did or if something accidentally got changed. I restarted the computer and looked for any settings but can't figure it out...Help Please!!!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Go into device manager and reset your display. Should fix the issue. First, though go into your screen resolution and check to see what the resolution is set as. Sometimes it can be as simple as hdmi cord not connected or vga cord. Unplug then replying back in.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thank you..thank you..thank you! Somehow the resolution had gotten changed.
door
Voeg je antwoord toe
lynn rebbing zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 21
Altijd: 369
