Ga door naar hoofdinhoud
Support and repair information for Beats Solo3 headphones.
Fixing no sound in one speaker on blueooth
I am having issues issues with the right side of my Beats solo3 wireless headphones. On bluetooth no audio comes out from the right side and the right side will only work if i jiggle the left side. Both sides work fine when using the aux cable for wired setup. What could be the issue?
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
5 Antwoorden
Het nuttigste antwoord
Plug in your auxiliary cord to your headphones to device, play some music, and if it works like that than take the auxiliary cord back out, turn on blutooth and both will start working again.
Was dit antwoord nuttig?
Score 2
8 opmerkingen:
I did it and it didn’t work. Twice. Help plz!!!!
door
It didn,t work for me either
door
Didn't work for me either
door
Didn’t work for me either.
door
I know this is old, but i just tried this and it worked
door
3 commentaren meer tonen
I have the same problem too
Score 2
If anyone is still having this problem I was able to fix my Beats Solo 3 Wireless issue with no sound on one speaker on bluetooth after I followed the instructions on this video: https://www.youtube.com/watch?v=kypDTpO_...
Hope this helps.
1 Opmerking:
This doesn’t help at all.
door
It could be a loose or damaged connection, would have to disassemble and inspect to determine the correct issue.
First try a reset etc.
Bruh I don't know what to tell
1 Opmerking:
Yeah you might need new ones
door
Voeg je antwoord toe
MrSnowyOwl zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 28
Altijd: 46,240
