Ga door naar hoofdinhoud
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 Vragen Bekijk alle
Is iPad Mini worth getting repaired after being run over by a car?
My daughter ran over her iPad Mini. It will not cut off, the screen looks fried but it's not cracked. The alarm clock still works and I can still tap it to snooze. The iPad is bent on one side, but looks perfectly normal elsewhere -- I was using an otter for protection; however the top of the otter was not on when it was run over -- just the back.
After reading some of the IFIXIT techniques, I am wondering if I would even be able to open it without issues.
Is dit een goede vraag?
2 opmerkingen
tulula007 post some images of the "injured" iPad with your question. That way we can see what you see. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that
door
Thanks! Am working now, but will as soon as I get home.
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Use the below guides to check your battery and LCD. If your battery is damaged at all replace it. Even if it isn't, you should replace it. Because the alarm still works, the motherboard sounds fine. Disconnect and reconnect the LCD cable, and make sure it isn't bent. If you don't feel like doing the somewhat difficult operating on it, it's probably about as cheap to fix it as you can buy a new one.
Hope this helps!
iPad Mini Wi-Fi Battery Replacement iPad Mini Wi-Fi LCD Replacement iPad mini Battery iPad mini LCD
iPad mini LCD Afbeelding
Product
iPad mini LCD
$49.99
iPad mini Battery Afbeelding
Product
iPad mini Battery
$29.99
iPad Mini Wi-Fi LCD Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
2 - 3 hours
iPad Mini Wi-Fi Battery Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
45 minutes - 2 hours
Was dit antwoord nuttig?
Score 4
If its an iPad mini 1st gen, then don't bother. Apple no longer updates this model for iOS. The last update was 9.3.5 and its now up to 10.3, so you are missing a lot.
Getting a housing, new LCD and simply moving the logic board over would cost more time and headache than simply buying a used iPad Mini 2nd that works.
Score 1
It's not worth fixing most likely bad LCD battery and shell and that would cost like $100 you can get a new unit for that and just sell this for 20 bucks on eBay thanks
Voeg je antwoord toe
tulula007 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 515
