Switch won't start engine
Engine will run when jumped @ solenoid but switch does nothing but turn on lights. Switch does have to be in on position to jump @ solenoid. Switch tests as good...wires are good. What else could it be?
Is dit een goede vraag?
2 opmerkingen
The earth ground wire was good but when I changed it's position from bottom to top of post...it worked...thanks for the tip!
door Ed Vernon Deel
Does it matter if what side the ground goes on. I have it hook up going from the sol. too starter ,
door Larry Farley Deel
