Ga door naar hoofdinhoud
De derde generatie van de Toyota Camry in alle markten buiten Japan. De jaren 1991-1996 worden ook wel de XV10-serie van de Camry-voertuigen genoemd.
Cam sensor location no spark issue
I have been trying to get this car going for about a year.told that the cam sensor is gone and need to replace it.now I'm no expert but I do know that I have watched a few videos on YouTube and where they show the cam sensor to be at it isn't..Then told that it's apart of the distributer shaft.!!!!! So if that's the cam where's the Crank shaft sensor? I ts a no spark issue
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
@lowvisions , Patrick , On the 2.2l engine, crank position sensor is behind the crank shaft pulley/balancer. Picture below(crank sensor circled). For the V6 3.0l almost same position, see video link. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=M6zU6jh8...
Afbeelding
Was dit antwoord nuttig?
Score 3
4 opmerkingen:
I'm sorry I should of mentioned that I have a 3.0
door
Patrick, For the V6 3.0l almost same position, see video link. Thanks for replying back.
door
On the 2.2 do u have to take the timing cover off to get to the sensor
door
We have a 1996 Camry LE 2.2L 4 Cylinder... I have bought the crankshaft position sensor, I just dont know where the heck to install it, where is the old one? Anyone know? I searched it up on youtube but i could not find anything. I hope someone can help
door
Hi for all Ihave toyota corolla 1993there’s no cranck shaft sensor but there's acumshaft sensor biultin within the main distributor shaft making signale to the ECU of the car
2 opmerkingen:
Well I have remove my 2.0 l and installed a 2.2 l engine , and the car didn't use a distributor , it uses coil which depend on a crankshaft sensor
door
@elicaannephembani And the point of bumping a thread that's almost 2yrs old is...? Are you having issues? Or what?
door
Voeg je antwoord toe
Patrick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 89
Altijd: 10,698
