Ga door naar hoofdinhoud
Apparaat- en reparatie-informatie voor het Behringer Eurolive B212D-luidsprekersysteem.
Loud hiss when turned on
Suddenly when I plug in and turn on my speaker there is a loud hiss.
I've tried different power cables and plugging into different outlets.. The hiss is evident whether or not there is a sound source plugged in.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
@townband , Steve , Unplug speaker and use the guide below to disassemble the speaker and spray switches with electro-contact cleaner and remove, spray and reseat connections to see if that gets rid of hissing. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Demontage Behringer Eurolive B212D Power & Bedieningspaneel
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
I will check it out. Again, the last people to use it were outside and unsupervised.
Who know what they did to it!
door
Steve, Good plan, look for water damage also then, if it does appear to have some on the board use this general guide link below, to to help clean of possible corrosion. Thanks for replying back, good luck with your speaker.
Electronics Water Damage
door
Het nuttigste antwoord
A hiss or buzz in a speaker system usually indicates a poor ground at the speaker . A solder joint may have let loose so that the wires still attached but not a good ground . You'll need to take it apart and check the grounds. Hope this helps
Score 2
1 Opmerking:
Great thought. I will try it out. The last people to use it were outside unsupervised! Thanks.
door
Voeg je antwoord toe
Steve zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 25
Altijd: 3,310
