Ga door naar hoofdinhoud
De Samsung WB350F-camera werd uitgebracht in 2014 en beschikt over 21x zoom en wifi-mogelijkheden.
Why does my camera scroll through the menu?
My camera continually scrolls through the menu when I turn it on and when I push the button to take a picture. Often, even when I push the button to take a picture, I cannot take the picture because the camera is scrolling through the menu, and this is visible on the display.
Is dit een goede vraag?
Score 4
5 opmerkingen
I have the same problem. ronaugermd@gamail.com
door
Camera constantly scrolls.
door
It's a great camera except it continues to scroll preventing taking a picture.
door
Same problem, and Samsung can’t even help… even though it says right on the box “PLEASE STOP AND READ CAREFULLY: If you experience technical when operating your Samsung digital camera or if the camera is not working properly, please contact the Samsung technical support center for assistance. PLEASE DO NOT RETURN THE PRODUCT TO THE STORE WHERE IT WAS PURCHASED. Our expert technical support team will evaluate the problem and provide the service your product requires. Please call 1-800-SAMSUNG (726-7864).” I called and was transferred to a guy who didn’t even know that technical support was SUPPOSED to deal with cameras. (*rolls eyes*)
door
REMOVE THE BATTERY ... REMOVE THE BATTERY, PRESS THE POWER BUTTON 5 TIMES ... THIS REMOVES ANY RESIDUAL POWER IN THE CAMERA .... CLEAN THE ROTERY SWITCH (camera top right corner) WITH ISOPROPOL ALCOHOL ON A COTTON SWAB OR COTTON BALL ... DRIP SOME ALCOHOL INTO THE CREVICE BETWEEN THE ROTERY SWITCH AND THE CAMERA BODY, ROTATE THW SWITCH A DOZEN TIMES IN BOTH DIRECTIONS AND ALL WILL BE FINE ...
door
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Het nuttigste antwoord
Found this: https://www.youtube.com/watch?v=_OyccVWY...
Temporary fix for a manufacturing defect.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Basically, you just put a few drops of isopropyl alcohol around the base of the functions dial and then you work the alcohol in by turning the dial (switching functions) for about 30 + seconds. Be sure to TAKE OUT YOUR BATTERY FIRST and decharge the camera after taking the battery out by pressing on the on/off button a few times.
All this does is clean out the dial, and the camera works again. It is a temporary fix. But at least it works.
door
this worked for me, do not be afraid, no damage occured ... camera works as it should after cleaning the rotery switch ...
door
Використовував цю інструкцію для розбирання Samsung WB350F scherm vervangen
Потім змочив у спирті ватну паличку і вставив у сервісний отвір
Afbeelding
Після чого провертав колесо “Меню” проти годинникової стрілки 30-60 секунд.
Після даної процедури, збоїв не спостерігаю вже близько пів року.
Score 1
2 opmerkingen:
This fixes the problem of broken buttons for the menu, not the above problem of the dial.
door
на фото червоними стрілками вказано, де треба чистити.
door
Voeg je antwoord toe
Jackie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 60
Altijd: 1,637
