Panasonic lcd tv Red light blinking problem
Panasonic LCD TV TH-L24C20D
Panasonic lcd 24 inch tv red light blinking continiuosly but the tv won't turn so please any one help me ,how do i solve this problem
Is dit een goede vraag?
Hi,
First try a power reset.
Turn off the TV and then turn off and disconnect the TV power cord from the power outlet. Then press and hold (or turn on ) the TV's power button (or switch) for 30 seconds and release. Reconnect the power cord to the power outlet and switch on the outlet. Turn on the TV and check if it starts OK.
If that doesn't work, switch off the TV and disconnect the power cord from the power outlet disconnect all the cables from the TV and remove the back cover from the TV.
Check the power board (the one where the power cord connections go to) for domed, leaking or blown capacitors and also for possibly any other burnt out or heat stressed component.
If unsure about a component take close up pictures of the component in question and post back here. Hopefully someone will be able to help you further.
Here is a link that shows how to do that.
Was dit antwoord nuttig?
My panasonic led tv also blink red light I was check up power board its good . What can happen?
पनसोनिक led tv 13 टाइम बिलिंकिंग कर के बंद होता है tv आन नही होता है प्राब्लम बताएं
Putting new batteries in the remote control cured the problem
panasonic th - 55ex600k can you help me ? after power tv led standby green than fast blinking than stop and turn red. the red blink many time .Blinking Red Lights Doesn't stop
Same like mine
Not very good advice taking the back off a TV if your untrained.
Most red light blink as ppl say is caused though breakdown of the power unit relays. Not to be messed around by an amateur
This was the issue with my one
Can you explain your photos as to how you fixed the red light flashing and no picture or channel being turned on?
@ammarhasanie how did you fix that? Same model a the OP?
Thanks for sharing, wow!
Any body what's the problem with my panasonic tv its blinking red light 9times . Its happen with 2days some time its turn on without blinking redlight and some time its not .i think my tv is their own mood?
Y board of your tv is problem
If you can change the board
if not
you must repair (change damaged electronics part) if you can know witch one is damaged
My panasonic iv is first time green led blinking and than no-stop red led blinking .what happen ?and what i check
Panosonic tv red light blinking
I have a Panasonic tv; It turns off after a minute and the red light flashes nine times. How can i fix this
I vacuumed the built up dust off the holes on the rear of the tv. It must have clogged the fan air intakes, so the tv was shutting down to stop it overheating and giving the blinking red light.
Mine is flashing 7 times so it's the SN board can this be fixed thank you.
@makawez same model? If so it could be your SN board as well as your PSS board. The boards are hard to fix since there are no schematics available but replacement boards should still be available
Mine does the same , flashing 7 times ,pauses then repeats. Help please 🙏
Any idea for TX-L47ET5B? Green lights when I turn it on and after it changes to 10 blinking light
That is a very good idea. I will do that tomorrow. 😃
Mine is just fine for hours, sometimes days and the it will shutdown with a flashing red light at 5 second intervals. I turn it off & on at the socket and it's OK again until the next time.
@majikthise what model is your TV? Sounds like something overheats or loses connection. What have you checked?
It seem like Panasonic tv consume light i dont understand anyone please
Model: TX-50CX700B around 8 years old.
I'm not positive but it may only do this through the HDMI inputs. I have DVD player, ROKU box & YouView box. At the moment I have it running through the TV inputs and it's been OK so far.
Panasonic Viera. Model number: TX-50CX700B
I`ve tried it with everything else disconnected and it still faults. Just switches off randomly with the flashing red LED every 5 seconds. There`s no pattern to it, it can do it 5 times in a few minutes or stay on for a week or more. At the weekend I took off the back panel and cleaned all the dust out of it thinking perhaps it was a build up causing a heat issue, still the same fault.
@claretsfan Did you ever get to the bottom of this issue. I have the same issue at the moment
(remote blinking red 5 times) Just chewing the batteries a little bit and putting it back in the remote could solve problem for sometime
Same problem
Afgelopen 24 uren: 109
Afgelopen 7 dagen: 604
Afgelopen 30 dagen: 2,647
Altijd: 379,205
70 opmerkingen
I tried (after trying several unsuccessful tips) switching off the TV for 1 minute (On the set). Then on the side of the set, holding the down program arrow button in and pushing and holding the on/off switch in until the remote light blinked green, keep holding it until the set came on. This was about 30 seconds. It worked. I notice that it now takes longer to get the set to start, but you can stop pressing the remote on once the indicator starts flashing green.
door Michael Oldman
Great advice, I used this ti fix my mums television, thankyou
door margaretannemelly
Amazing advice, thank you. We were just about to get rid of our tv as we could not turn it on. It is a 7years old Panasonic so we thought might as well replace it. Anyway cam across your advice and it worked.... great no need for a new one
door arianedecloux
Thank you for posting this! Thought out tv was a goner. Tried this and it worked!!!
door Joe Anderson
You are like an angel for tv’s
door Trey Sawey
65 commentaren meer tonen
