Ga door naar hoofdinhoud
Algemene reparatie-informatie over LG-wasmachines.
hi washing machine faults out on OE error .
hi i have checked the drain hose , cleared the filter , and also checked the pump is spinning freely . issue isnt present during mid cycle . water is draining during wash but near the end of the cycle the drain issue becomes apparent and it faults on the OE code .
Is dit een goede vraag?
Score 3
10 opmerkingen
hi i have same front loader i have 3 lines showing where the time of cycle should view.
door
Just to add to this I took mine apart and just cleaned the pump and it has been working for a year-and-a-half since. The pump basically has no moving Parts it's a magnetic impeller mounted in a housing. Took it apart cleaned it I threw a little bit of a light oil where the shaft of the impeller sits in the pump housing. Don't waste your money on buying a new pump if your pump is trying to pump and it can't it's probably just a dirty impeller. Very easy fix and it was free!
door
My machine shows t lc
wat does that mean it’s not in booklet
door
LG smart drum being DUMB.
IT'S not making connection to pump on draining cycle?
What else could be happening,
I replaced with new pumps
2 x ,everything works if I lay hose on floor on draining cycle. Can my main board be damage? Or can I replace a contact or something?
door
I had the same problem with oe code, took machine apart nothing in pump or hose, no filter on my top load model, so I tested the water fill valve by unplugging the machine while it was filling and it did not stop flowing water. Ordered the water fill valve assenbly for 32.00 replaced it in 10 minutes and my machine runs like a new one with no code!
door
5 commentaren meer tonen
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
The error code "OE" is a Drain error.
Cause 1
Drain Pump
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
Cause 2
Clogged Pump or Hose
Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Remove the hoses from the pump and check for any obstructions.
Cause 3
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not drain. To determine if the lid switch assembly is defective, use a multimeter to test each of the lid switches for continuity. If a lid switch does not have continuity, replace it.
Was dit antwoord nuttig?
Score 4
12 opmerkingen:
hi ,cheers for the answer . found the impeller was semi seized have ordered a new pump unit . door switch was perfect . thanks again
door
Glad I could help solve the problem ;-)
door
I replaced a pump with a new one. ran one cycle successfuly. now sasme problem again. when I run Spin only it starts this very long slow spin, and it does NOT seem to even engage the pump...
door
Sharon see if the drain hose can be cleaned out
door
I am having the same problem as Sharon Eilon and checked both hoses and nothing in them.
door
7 commentaren meer tonen
When you guys are replacing your pumps do they come with a new housing and impeller or just the electric motor? Mine was giving me all kinds of problems till I finally dug into it today and found that the impeller was the problem. Pried the impeller out of the housing cleaned it all out regreased it and the machine works like a charm now.
1 Opmerking:
SOLVED WITH VIDEO https://youtu.be/RUbIKBch7pY How to - LG front load washer OE error code. This is a long (21 minute) step by step video on how to take apart your LG washing machine and replace the pump to get rid of the OE code. If you look at the troubleshooting page in the manual, it will explain some first steps on how to fix it like checking the hoses etc. If you follow that and the machine still won’t empty out the water then you need to replace the pump. If you lost your manual we have a direct link to that page for your reference. The video also lists all of the tools and parts needed and provides links to them as well.
door
Hi @rafitas ,
What is the model number of the washer?
Is the machine not draining at all, draining too slow in the allocated time or just not draining completely?
You state "....,everything works if I lay hose on floor on draining cycle."
Have you checked the drain itself to make sure that it is not clogged etc, therefore not allowing the water to flow away freely?
Voeg je antwoord toe
csheedy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 150
Altijd: 70,635
