Ga door naar hoofdinhoud
Cobra 29 LTD Classic. 2-way 40 channel CB radio. Features antenna warning indicator, SWR calibration, instant Channel 9, PA capability, dimmer control, switchable noise blanker and RF gain.
10 Vragen Bekijk alle
keys 4watts no forward swing
cobra 29ltd classic keys 4 watts no forward swing.new mic new final new ic chip tda2003 new driver
Update (12/21/2016)
I don't know about a d104 but the d11 has been removed by me it has no modulation so it will not swing forward
Is dit een goede vraag?
3 opmerkingen:
If it is not ic3 more than likely it will be ic1 pll chip .have had several with key up but no modulation output and it turns out to be the pll chip.
door
have you tried a different microphone
door
yes mic was good. I got it tr17 shorted thanks
door
Voeg een opmerking toe
1 Antwoord
Was the D104 diode clipped or removed? If not, remove the whole diode... If this is not removed, you won't get full modulation or watts. It must also be peaked to match the new driver and final.
This is just off the top of my head without you providing final and driver information, also assuming you upgraded the CB.
Was dit antwoord nuttig?
Voeg je antwoord toe
mark zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 975
