Ga door naar hoofdinhoud
Sony M-430 Microcassette-Corder can record and play back audio. The one-touch recording and two-speed record/playback and automatic shut-off makes this ideal for on the go recording. Model number M430.
9 Vragen Bekijk alle
Drive belt replacement, replacement parts
Where can I obtain a replacement drive belt for this unit?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@cestrangio , Christopher use the links below, 1st link is Sony parts page where you could inquire about availability and the other links are belt suppliers that may have a suitable replacement for your M430. Good luck.
https://esupport.sony.com/US/p/model-acc...
http://www.thevoiceofmusic.com/catalog/t...
https://www.kenselectronics.com/lists/be...
http://www.gbaudio.co.uk/data/belts2.htm
Was dit antwoord nuttig?
Score 3
4 opmerkingen:
@lpfaff1 Wow I'm impressed you were able to find anything on something so old . Nicely done
door
@jimfixer , thanks Jim, and what about you where did you find that B code, I thought they only went up to B3000, good job on that one.
door
Hi @jimfixer and @lpfaff1
If ever you need belts here is one good resource for most belts. Although would you believe the one being asked about wasn't there!
http://www.russellind.com/client/downloa...
door
@cestrangio and just in case you need it, the Sony part number for the belt is 3-377-420-11
door
Voeg je antwoord toe
Christopher Strangio zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 25
Altijd: 2,737
