Ga door naar hoofdinhoud
Ondersteunings- en reparatie-informatie voor Marantz home-theater-AV-ontvangers en oudere audio-ontvangers.
Why won't my amp turn on?
I have a Marantz model 1040 amplifier that wont turn on. I checked all of the fuses, they are good, and when the amp is plugged in, I can get power through one of the outlets that is on the back of the amp. Still doesn't turn on. Not sure where to start.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
kalewenczel I'd start by looking at the power supply for the amp. You will have to disassemble it. Take plenty of pictures and post those with your question. Use this guide for that. It will allow us to see what you see. Check the large capacitors and diodes on the power board. Attached image shows the location of the parts
Afbeelding
and here is the schematic for it
Afbeelding
You do not just want to check the fuses for continuity but check to see if you have power on them as well. Let us know what you find.
Was dit antwoord nuttig?
Score 4
Check the power switch on the receiver. Make sure is is getting power to it and not broken inside. This units are notorious for this.
Voeg je antwoord toe
kalewenczel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 26
Altijd: 8,815
