Ga door naar hoofdinhoud
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
NISSAN ALTIMA 2006 2.5L engine shaking
for some reason last night I turned my car on it was shaking and the car engine sounded weak like if it was going to turn off while I was in parked gear. once the car warmed up I put it on drive I can still feel something from the engine was shaking and the service engine soon yellow light was flicking until it stayed on. this morning I turned the car on no shaking and the service engine soon light went off, any idea what can cause this shaking coming from the engine?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
if your car was shaking it was probably not running on all cylinders . Check to see if the computer threw a code and tells which cylinder was the culprit . If you don't have access to OBDII code reader then head to an auto zone or parts source and they'll read it for free. Odds are one of your coil packs is starting to fail it will tell you if there is a problem here and which pack to change. Hope this helps
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
manny gomez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 13,041
