Why isn’t my Thinkpad charging?
The Thinkpad is properly plugged in at both ports but is not building a charge at all.
Is dit een goede vraag?
Krijg snel toegang tot handleidingen, onderdelen en antwoorden voor jouw apparaten
Test the power cord with a multimeter like in this guide.
Continuïteit van een netsnoer testen
Then I would also test the power adapter is it is working with the multimeter
Hoe gebruik je een multimeter?
If both test work fine then you know that your power adapter is fine and working.
You should also look at the power connector on he laptop so it is not loose because then the soldering might not lead the electricity. Good lock in testing.
Handleiding
Moeilijkheid:
Zeer eenvoudig
1 - 5 minutes
Handleiding
Moeilijkheid:
Eenvoudig
5 minutes
Was dit antwoord nuttig?
Try replacing the battery or buying a new charger.
Try pressing and holding down the power button for 3 - 4 seconds with the battery removed. Then try putting the battery back in, along with the AC adapter and see if it will charge. If this does not work try updating your motherboard.
If none of this works then try purchasing a new battery and AC adapter.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 405
1 Opmerking
student question
door Jimfixer
