Ga door naar hoofdinhoud
De Minolta QTsi Maxxum is een automatische camera. Deze beschikt over een paar bijzondere functies, waaronder vijf vooraf ingestelde belichtingsmodi, een afneembare 35-80 mm zoomlens en een automatische pop-upflitser met vier standen. Het modelnummer van het apparaat is 312875.
Why does my camera randomly shut down?
Sometimes my camera will shut down when I am taking photos and I don't know why. Any thoughts?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Sometimes your camera may shut down due to a malfunctioning power supply.
Remove the batteries from your camera for 30 seconds, put them back, and then see if that solves your problem. If the issue continues, try replacing the batteries all together.
If your camera still turns off frequently, it might be suffering from an overheating problem. That can progress into further issues, so you should check out the overheating section of this troubleshooting page. It also address different problems that may occur with your specific camera.
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
@jordanellery , Jordan, Minolta QTsi Maxxum shuts down when I am taking photos, try different battery, ensure batteries are healthy and charged check in your cameras settings or if timer is set, to see if camera is in power save mode. Link below is a manual for your camera. Good luck.
http://www.tashimareport.info/Minolta/si...
Score 3
I have a X-300 and im having a similar problem where I get lights indicating the battery being exhausted despite the batteries being fresh and new. I looked it up and im pretty sure it's from a faulty capacitor. You might have the same problem, the good news is theres a way to fix it, the bad news is you need to have a screwdriver, and a soder gun, If you do you can follow this tutorial https://www.google.com/url?sa=t&rct=j&q=... If you don't you might be able to send it somewhere to get fixed.
Score 1
Voeg je antwoord toe
Jordan Ellery zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 41
Altijd: 4,258
