Ga door naar hoofdinhoud
The Wii U is a video game console paired with a handheld device made by Nintendo that allows users to play games on the GamePad. Repairing the console is straightforward as the device is very modular.
Repairing/replacing console AC adapter port
The AC adapter port on the console feels loose. Whenever I plug the power adapter I need to move it in different positions in order to power up the console. I was wondering if it's possible to just solder it correctly or replace it?
I found the part here but would it be just a matter of soldering it in place?
Thanks.
Is dit een goede vraag?
Score 1
1 Opmerking
crazy ive been having the same problem thx for the anwsers on this guys post ill keep yall updated
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I would first try to solder it on again, should usually work.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
So, I made something stupid: I was trying to solder the part. I made several attempts and I couldn't get it to work. Now, before I was able to play sometimes by adjusting and moving the power cord in different ways. So me being stupid I plugged the power cord and attempted to solder the part while it was connected to find the sweet spot and put the part in place... and I got a spark and now I can't make it work, doesn't matter how much I move the cable. How can I test if I damaged it?
door
Well, at least I know I didn't kill it. It still works but even after soldering in place it's still hard to make it work. Thanks.
door
Definitely try re-soldering it back in place first. Sometimes it can get loose and all it needs is some fresh solder to keep it in place.
Voeg je antwoord toe
Ruben Tenorio zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 2,072
