Ga door naar hoofdinhoud
The LG Optimus L7 P705 has a 4.3 inch LCD screen and weighs 4.3 ounces. It has a 5 megapixel camera and a LED flash. It houses 4 GB of internal memory with a SD slot that holds up to 32 GB of memory.
when I press power switch phone stared but phone loading countinusly?
when i press power switch phone stared but phone loading countinusly ?
phone showing me lg brand name
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
DId you do a software update recently?
Have you dropped the device or has it been exposed to water in any way?
Sounds like you are stuck on a boot loop and will have to either restore to stock firmware via download mode.
Check this guide right here for additional info. It would honestly help if you put the correct model identifier. Biut I am assuming that is it.
Good Luck!
Was dit antwoord nuttig?
Voeg je antwoord toe
Atriswar Paul zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 10
Altijd: 115
