Ga door naar hoofdinhoud
The Dell OptiPlex 745 small form factor is a compact desktop computer that has been a work office favorite, and still sits at desks to this day.
16 Vragen Bekijk alle
Which Motherboard Perfectly Supports in DELL Optiplex 745?
I have a DELL Optiplex 745 Small Form Factor PC,
and processor is Intel Core 2 Duo e6420.
My motherboard has failed, so i need to replace motherboard. I'm in trouble to solve this problem. which motherboard(s) should i choose ?
Is dit een goede vraag?
1 Opmerking
Well, Thank You Very Much Simon Almeida For Your Support. Yes, you said right, my machine is old. I would like to think about changing it :)
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Your motherboard size is called "MICRO-ATX" and you CPU socket model is "LGA775". So any "Micro-ATX LGA775" motherboard will work (Assuming your CPU and other components are still good).
Here are some motherboards I found online:
  1. http://www.ebay.com/itm/NEW-Foxconn-G41M...
  2. http://www.ebay.com/itm/Intel-DG35EC-Des...
  3. http://www.ebay.com/itm/ASUS-P5G41T-M-LX...
  4. http://www.ebay.com/itm/NEW-Gigabyte-GA-...
My personal opinion, I would recommend buying a new computer. Your machine is 8 years old now. A lot has changed since. I don't think you will regret this decision :)
Best of luck!
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Sarthak zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 1,764
