Ga door naar hoofdinhoud
The Airport Time Capsule is a wireless router and network-attached storage (NAS) device manufactured by Apple. Model A1409 is the fourth generation revision of the Time Capsule released in June 2011.
No Response and unable to reset
Hi
My Time Capsule currently not working probably, the light turn to yellow, no wifi signal, unable to connect the AirPort drive and unable to reboot or reset.
This happened the second time this year, the problem found last time I bought to repair but extremely expensive. And the same problem came with out again, does anyone got idea how to fix it (at least I want all my files back)
Many Thanks
Christopher
Is dit een goede vraag?
1 Opmerking
What was done to repair?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If you just want your data you can open the time capsule. It´s a normal sata drive. Plug it HDD in a new caddy and restore the data.
Was dit antwoord nuttig?
Voeg je antwoord toe
Christopher Ma zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 664
