Ga door naar hoofdinhoud
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
Why my game boy not charging?
So I had this game boy for along time but the ac adapter broke and after a lot of years a bought a new one but now the console is not charging at all... not even the red light goes on when I put the charger but the console still goes on and since the battery is dead it goes off right next
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
First of all, check the current output of the charger. If that value is equal or above the one on the original, then the battery is dead and you should get a new one.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Where can I get a new GBA SP battery? Does Nintendo still manufacture them?
door
A place where you will surely find one is ebay. Or Aliexpress. Sorry for the late reply.
door
Just a quick note, all batteries on eBay are probably not up to full capacity, so they won't last as long as a brand new one. Just pointing that out.
door
I would recommend getting a new battery as Ciprian R said above. If that doesn't work than it might be the actual connecter on the GameBoy. Take a quick peek inside it to see if there are any bent pins or any loose wires or such.
Voeg je antwoord toe
arthurpotterkarate zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 5,113
