Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De C720 is een goedkope Acer Chromebook op basis van ChromeOS. Uitgebracht in 2014 als opvolger van de C710.
Why did my computer froze?
I was working on my online quiz and it froze on me my mouse was pointed at the scroll down area.
Is dit een goede vraag?
1 Opmerking
amiller364 there are lots of reasons for why this may have happened. Did you get it restarted? Any issues with doing that?
door Deel
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
amiller, Shut down ( hold power button 10 seconds) and restart, run a malware and virus check as this could be an infection.
I hope this helped you out, if so let me know by pressing the helpful button. Good luck.
https://chromebook.guide/chromebook-viru...
Was dit antwoord nuttig?
Score 1
Also look into running a power flush on your device. This can be achieved by following Googles Chromebook reset instructions:
(In your case you would shut it down and use the keyboard short cut in the login screen)
Sign out of your Chromebook.
Press and hold Ctrl + Alt + Shift + R.
Click Restart to restart your Chromebook.
In the box that appears, click Reset and sign in with your Google Account.
Note: The account you sign in with after you reset your Chromebook will be the owner account.
Follow the instructions in the box.
Once you've set up your Chromebook, check if the problem is fixed.
THIS WILL RESET YOUR CHROMEBOOK but being a google device all your pictures, documents and the like should be online in the google drive.
This will fix %95 of software issues.
If it does not look into creating and using a recovery USB drive and finally if that doesn't work chances are it's hardware and being a chromebook it's often simpler to replace it.
Voeg je antwoord toe
amiller364 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 647
