Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
microphone on iPhone 6 not working
hi!
i have an issue whit an iphone 6 the microphone is not working either on regular call , handfree, or even bluetooth i tried replacing both microphone top and bottom
i also tried put on and off noise reduction soft reset hard reset ios update and DFU
so at this point i dont know where to look for to solve this problem
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Considering everything else you have tried it is probably an issue on the logic board somewhere, I would get someone who has experience with logic board repair to have a look at it.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
i sent an e-mail to ipad rehad i hope have news soon
door
Did you ever get this figured out? I am having the very same issue.
door
Hey Old pal!
Heres a post I wrote on iPhone 6 microphone problems
If this dosent help I think you'll need to replace the ic on the board
Did you have any luck?
Blue skies
BT
Hope things are going well!
Score -2
6 opmerkingen:
@screenfixedau your answers are currently being marked as spam. On this part of the forum we let you help others by providing solutions. We do not tolerate linking to your own site, services or blogs. You can add those links to your profile and refer to that in your answers. You do want to stop that practice!
door
@refectio @nick @alexniculescu I did not delete the question but did downvote it to give @screenfixedau an opportunity to review his answers. We do have to give anybody a chance to learn the rules before banning for Spamming. Consider to reverse your vote in moderation until we recognize which way the user is going. If it is going to be a habitual spammer I will delete this answer immediately
door
@oldturkey03 yeah, I initially marked if for moderation but then noticed that the contributor had done it several times yet was clearly trying to help. That's why I brought it up on meta. However, I think mayer dinged him already...you might want to consider changing that.
Hopefully Ben will continue to contribute.
door
I've reversed mine this time @oldturkey03. I may not do this a second time.
door
@nick your call. You do not have to do anything anyone tells you. It was a suggestion not a demand.
door
1 commentaar meer tonen
Voeg je antwoord toe
Reparactif zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 315
