Ga door naar hoofdinhoud
The Samsung Galaxy S4 Active is a rugged version of the Galaxy S4. Currently, it is only on AT&T's 4G LTE network.
20 Vragen Bekijk alle
Can I use a different model to replace the LCD?
Okay, I have the Verizon version of S4 SCH-I545. The LCD needs to be replaced. I also have available a working LCD from the ATT I337 S4 which includes the frame. I read that they have different frames and home flex so you can't just use any version to replace LCD.Can I just switch the LCD to the Verizon model motherboard?.Do all the motherboards match up? Can I just transfer all the parts to the I337 LCD frame? Or is the home flex connection different on the verizon motherboard?
Is dit een goede vraag?
Score 1
1 Opmerking
It says that the S4 active is AT&T only... Is it unlocked?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
No. The Samsung Galaxy S4 screen is completely different from the Samsung Galaxy S4 active screen. Neither will work on the other.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Are all the ATT S4's using an active screen? I don't know if mine is active.Anyway to check?
door
yeah i have a galaxy a50 and the model is a505U and i used a a505f, it was working fine at first then vertical lines started appearing. it’s most likely because the different models.
Score 1
Voeg je antwoord toe
xsilicon9 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 7
Altijd: 1,534
