Ga door naar hoofdinhoud
De Jeep Grand Cherokee werd opnieuw ontworpen voor het modeljaar 1999; de 2000-modellen hebben minimale wijzigingen. Dit model staat ook wel bekend als Jeep WJ.
Cabin air filter location
Where is the cabin air filter located on my 2000 jeep grand cherokee?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
@holbrooks all 1999-2004 Grand Cherokee WJ series models feature a housing for installation of a cabin air filter but no models have ever come with the filter as standard. It must be purchased as a Mopar aftermarket accessory and installed under the front cowl. So unless you had it installed, there isn't one.
Was dit antwoord nuttig?
Score 4
1 Opmerking:
If the jeep grand Cherokee was instald from factory 2001 jeep grand Cherokee owner it could be with glove box removed it is right above GB in small square compartment and #2 under windshield cowl passenger side is a long rectangular air filter in an in closed plastic box that snaps together the original filter had charcoal lined element.
door
There isnt one unless an after market filter has been installed.
1 Opmerking:
Just like fans I had two one was installed under the front cowl and one is in a cabin behind the glove box lucky f****** me I mean why would you have two fans you know how hard the water pump is to change or the thermostat cuz an engineer had something to do with it
door
Voeg je antwoord toe
Michelle Holbrooks zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 81
Altijd: 34,154
