Can it fixed from water damage
fell in a tub of water and just went blank, not charging not turning on its just dead
Is dit een goede vraag?
Mpho Leboho you treat this just like any other submersion. it is a bit of a guessing game as in how your phone will respond to a proper cleaning. The importance right now is to not turn it on, or trying to sync/charge it. Remove the battery, and disassemble it by using this teardown carefully . Clean everything with isopropyl alcohol (90%+) and a soft brush, including all connectors and cable ends. Clean it properly using this guide. It was written for a iPhone 3G but all the points still apply to your phone as well. Remove all EMI shields and check for any burned or missing components. You may have to repeat this step a couple of times. Once it is cleaned, reassemble it and replace the battery, then reevaluate for any real damage. Right now, everything will only be a guess, and the longer you wait the more corroded it will get.
Handleiding
Moeilijkheid:
Moeilijk
1 - 2 hours
Handleiding
Moeilijkheid:
Gemiddeld
Was dit antwoord nuttig?
Put it in a packet of rice
This is exactly what I did. Stuck it rice for 2 days. Plugged the phone in and it booted straight into eRecovery mode.
It didn't work for me
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 15,115
2 opmerkingen
In water for long time. Disassembly it, clean, and replace battery with a new one but no charge and nothing on screen what now? On the trash ? TU. Byez.
door Doriano M
Hi, u can change the screen first, and if nothing works the charging port and the battery father that if nothing works your phone is dead. I have fix phone who has pass 5 days in the river in the winter and I'm living in the great north of Québec. After changing the screen everything was good.
door FIX ton Phone
