Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Panasonic TX-32LX70 is een 32-inch LCD-televisie (liquid-crystal display) met hoge definitie van Panasonic.
Cut (Crop )image up negative down normal
Plz suggest me how to repair my Tv.
Last 2 dy my Tv screen cut image .
Tv up side like negative screen & down side Normal so plzz
what's problem...
My tv num :panasonic tx-32lx70c
Update (06/06/2016)
Afbeelding
See attached file and plzz suggest
Is dit een goede vraag?
Score 2
3 opmerkingen
@mayur could be a panel issue. Just to verify your image appears cropped, upside down and inverted? Post some images of what you see with your question. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that.
door Deel
@mayur the grey on the bottom of the TV's display or is that just on your picture?
door Deel
That's just on picture,
But top side defect( black sheds ),
See channel name line
Cut he face..
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
@mayur unlikely that this would be caused by a bad LCD or a bad driver logic. I would suggest that you start with your settings first. Make sure that you have things like "mirrored" etc. not accidentally turned on. If your menu has a factory reset, try that.
If you are 100% sure that your settings are right and that a reset did not resolve this, you'll have to open up your TV and take a look at the boards. Check for obvious damage and post images of those boards with your question.
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
What's Problem My Tv.
Plz Tell Me Details...
I hve open My Television And Clean Dust Also.
Bt No Idea What Can I.
So Plzz Explain Me..
This Problem Faced Last Two Weeks .
Power Shut From Electricity .When
Power Come That Time To Till Date This Problem Faced..
I Don't Understand What's Problem on Television..
door Deel
@mayur Have you done a complete reset yet? Go into your TV's setup menu
door Deel
Which side show reset menu
door Deel
Voeg je antwoord toe
mayur zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Altijd: 739
