doors do not close completely
bifolds do not close completely One or the other bifolds closes but nut both. There doesn't seem to be enough room. How do I adjust both top and bottom? Don't seem to be able to get the hardward far enough into the corner. Top seems to be the problem but I'm open to suggestions
Is dit een goede vraag?
Some pictures might help.
door mayer
Hi, Have you measured the width of the door opening (inside of door frame to inside of door frame) at the top. middle and bottom (not all frames are perfect) and also the width of the doors plus what is needed for the hinge gap to see if they will fit.
door jayeff
