Ga door naar hoofdinhoud
The Lenovo A7 tablet is a 7-inch Android tablet released by Lenovo in April 2015. The A7-30 tablet was released in two versions, the 3G/Wi-Fi model (MediaTek MT8382M) version, and the Wi-Fi only (MediaTek MT8127) version.
33 Vragen Bekijk alle
Why has my screen gone wrong?
I turned my tablet on and all was working ok then all of a sudden the screen went like white/grey all over. It's not been knocked or dropped and is always protected in a case at all times. What has caused this to happen? It is only 3 months old.
Is dit een goede vraag?
1 Opmerking
You can't even remove the back on the device.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
This is a problem with the Lenovo . You could try a hard reset to restore it to factory defaults - you will lose all your settings and data.
Here is a link to show you how.
Lenovo A7-40, A7-50 A3500 Factory Reset
If it doesn't work after that, given that it is only 3 months old, contact the manufacturer about a warranty repair or replacement.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
The screen is absolutely blank so can't see or get to the settings.
door
Voeg je antwoord toe
Nicole Smyth zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 220
