Ga door naar hoofdinhoud
Lenovo A7-40, A7-50 A3500 Factory Reset
Wat je nodig hebt
Video overzicht
  1. Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: stap 1, afbeelding 1 van 3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: stap 1, afbeelding 2 van 3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: stap 1, afbeelding 3 van 3
    • 1. Switch of the tablet. If the device freezes, you can use a reset hole under the memory card reader cover.
    • 2. Press and hod: Volume Up + Volume Down + Power buttons.
    • 3. In the Recovery menu, use the Volume Down button to move the highlight and the Volume Up to select.
    • 4. Choose one by one: "wipe data/factory reset", "Yes -- delete all user data" and finally "reboot system now".
  2. Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: stap 2, afbeelding 1 van 3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: stap 2, afbeelding 2 van 3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: stap 2, afbeelding 3 van 3
    • 1. Switch off the tablet.
    • 2. Press and hold the Volume Up and Power On keys.
    • 3. When you feel release only the Power button. Now your device is in Factory mode.
    • 4. Use the Volume Up/Down keys for movement and the Power key for select.
    • 5. Select ¶§ eMMC (Clean eMMC)
    • Did you do it successfully?
Conclusie
33 andere personen hebben deze handleiding voltooid.
ZFix
191.368 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
321 Leden
1.466 handleidingen geschreven
17 opmerkingen
let me try and see
usman aleeyu - Antwoord
Is it applicable to my lenovo a516?
valvinzon - Antwoord
yes it works thanks
abdullahjanajy - Antwoord
Love you so much goodnight baby
Van Prince -
Well thanks!! I was worried about my tab and now i can fix easily tab without paying others to fix my tab. Thank you again :))
Christian Lemuel Espenilla - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 40
Afgelopen 30 dagen: 126
Altijd: 106,204
