Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Microsofts derde generatie Xbox-spelconsole, uitgebracht op 22 november 2013.
Xbox One turns on then turns off after a few minutes
My Xbox one turns on and I am able to use it for a few minutes, but randomly turns off. I tried playing Destiny and Forza 5, but as soon as the game loads, it shuts off. The last update that it got was the June 2015 update. Sucks, because it broke on the first day of summer vacation. I contacted Microsoft support, but they said I would have to send it in...I want to see if I can fix it before I do that. I have tried to turn it on recently, and when I do there is a system update. I tried to update it, and it starts doing the update. It was almost done but the console shut down on me.
Please Help!
Is dit een goede vraag?
Score 10
14 opmerkingen
Well, I tried and Unfortunately, it didn't work... I have to send it to MS, they will give me another one... Still gotta pay $115 though...
door Deel
I'm not sure if this matters but i just remembered that it was stormy the day before it pooped out....not sure if that screwed it up or what.
door Deel
my console shuts itself off, im wondering if yours is doing it the same way. when mine shuts off (which is very frequently, in fact im not even using it anymire until its fixed) you can here a click inside the console, i think thats where the problem is. PC's have this problem too.
door Deel
also its not overheating i promis you, one morning, after it was off all night, it wouldn't turn on.
door Deel
@tronicsfix cockroaches?
door Deel
9 commentaren meer tonen
Voeg een opmerking toe
9 Antwoorden
Filteren op:
Gekozen oplossing
It sounds like it could be overheating. I'd take it apart and clean it out of any dust with some Dust-Off or similar.
Xbox One-ventilator vervangen
If that doesn’t help, try some of the other solutions in the Xbox One Turns Itself Off wiki.
Was dit antwoord nuttig?
Score 5
13 opmerkingen:
Ok, Thanks! I will have to try this. also when it turns off the power brick turns orange and idk if the console makes this sound or the brick, but it makes a little click right before it turns off
door Deel
I would assume that's from the device itself rather than the power brick. It is likely the fan coming to a stop or other component. How long have you had it, and in what condition is it kept in? Is there plenty of ventilation in the area?
door Deel
I have had it for about a year, It is well ventilated, there is no wire around it besides the power, and HDMI.
door Deel
Wow that's odd. That's my only explanation other than maybe it got damaged over that year? I don't know how well you take care of your Xbox so i don't really know
door Deel
I would still take it apart. You'd be surprised how much dust can collect in there and it can really fry your mother board if you don't stay on top of it. Even my laptop has to be opened up and cleaned.
door Deel
8 commentaren meer tonen
This happened with my 360 every once in a while. I just put a fan on my Xbox and put it on an open surface not in like a shelf where is covered.
Score 2
I spilled milk in my Xbox and I blowed dryed it out and it turns on and stay on for 15 mins then shut off any solutions?
Score 1
2 opmerkingen:
Did you take it apart to dry it? If you did, make sure there is still thermal paste between the cooler and the chip below it. Without that, the CPU/GPU will overheat, and then, of course the xbox will protect itself, and shut down. If you didn't take it apart, I would, and then look for anything resembling milk, corrosion, or burnt components.
door Deel
@josiah Fixing an xbox one s for my uncle that has this problem. when i took it apart, the underside of the motherboard was covered in what looked like rotten milk or melted ice cream. is q-tips and 91% isopropyl alcohol a good method of cleaning the motherboard? it may be in other components too but i've yet to find any
door Deel
i spilled milkshake on my xbox
Score 1
Anyone know why my Xbox one keep turning off when I turn it on
I have the same problem too. It turns on for a few mins. and then suddenly turns off. I am going to take the cover off and clear all dust
So I unplugged my Xbox 1 s as it was on and brought it stright to my friends but when I hooked it up it turned off instantly ten I waited a hour and turned it off and it turns off after like 7 mintues
1 Opmerking:
my xbox turns on and then shuts off
door Deel
Ok so with my Xbox it does the same thing, it turns on then turns off I've taken it completely apart and blew on it but and put everything back but it still does the same thing, turns on then off. I've also done the power box thing unplugging it the plugging it back in and I show the lights that it's supposed to but when I go to turn it on it still won't work it still turns on then turns off. Yo can anyone help me with this because it's making me hella mad not cappin.
So I turned on my Xbox 360 and it immediately shut off and turned the power button red, I’m not sure if the previous owner dropped it or anything but the fan is coming on and it is in a ventilated area just not coming on.
Voeg je antwoord toe
Nadeem Baksh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 62
Afgelopen 30 dagen: 113
Altijd: 98,035
