Ga door naar hoofdinhoud
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
20 Vragen Bekijk alle
bubble in the screen after repair
I just replaced the glass on a s3 and now have a tiny dot in the center of the screen .I have done many screens as well as digitizers on all kinds of android and iphones this is a first for me and am wondering what went wrong.The digitizer did not appear to have any defects and it was done in a dust free box so I don't think its dust. Its about the size of a pin head and the screen works fine.
Is dit een goede vraag?
Score 8
4 opmerkingen
Has this ever happened to anyone else.It almost looks like water under the screen
door
my phone has this to after i get screen fixed has little bubble in middle you can move around and looks like water how do i fix this to
door
Maybe the backlight is damaged?
door
THERE IS NOT A BACKLIGHT ON A SAMSUNG AMOLED DISPLAY.
For that matter, its not an LCD, stop calling it one. Familiarize yourself on the technology of the devices you're working on and offering advice about. Knowing how and why a display works will go a long way toward finding real solutions instead of searching around in the dark like a blind squirrel.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Most likely you didn't properly repaired the device the correct way.
That usually happens when you replace the glass and don't bond it with oca (optical clear adhesive) or loca (liquid optical clear adhesive). I've use to do this, when I first started repairing phones. Now I use loca to bond them, making every repair look just coming out the manufacturer as possible.
Was dit antwoord nuttig?
Score 5
3 opmerkingen:
Will adding heat after the install help
door
Finally took the screen off and reapplied the sealant and reseated to correct the issue. A small doubling of the tape caused the issue
door
sounds like you answered your own question
door
Voeg je antwoord toe
Jimfixer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 25
Altijd: 11,791
