Ga door naar hoofdinhoud
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
20 Vragen Bekijk alle
Lines across bottom of screen
I have 2-3 thin lines across the bottom of my 1st generation iPhone. It does not prevent me from moving the lock screen button and getting on to the main screen, but I would like the phone to be in perfect condition. Can you tell me what part needs to be replaced and how difficult a job it is to do??
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Here is a list of steps you can try!
  • Software issues
    1. Restore (Google it) Back up first!
Or
  • Hardware Problems
    1. Bad Screen (Change It!)
    2. Bad Logic Board (Change it too! HARD and Back Up first!)
Hope I helped!
Was dit antwoord nuttig?
Score 1
Original iPhone front screen replacement is among the most difficult iPhone repairs there is. Watch a few youtube videos to see the process. Unless you have extreme skill, you will not even be able to open this iPhone without permanent damage to the iPhone case. In the future, if the battery eventually fails, battery replacement is much easier, but again, a very difficult process. The Original iPhone is not a repair friendly iPhone.
I assume it is CHEAPER if you buy a used NEWER iPhone for less than 100 € than trying to replace the display !
I have the same problem since several years, and have upgraded first to 3g and now a 4s model in the meantime
Voeg je antwoord toe
pbassey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 607
