Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Een zwembad is een reservoir gevuld met water, bedoeld om in te zwemmen of voor recreatie in het water.
Salt Chlorinator Cell Repair
I want to find out how to repair a Salt Chlorinator Cell? It's a seemingly sealed unit with two electrodes inside which convert salt to chlorine. These electrodes get worn out or used up over time. Can these be replaced or replated? Any special tricks and things to know? Anything to be aware of so as not to mess things up? What's the worst that could happen?
Is dit een goede vraag?
Score 1
1 Opmerking
What make and model? Post some images with your question so we can see what it looks like and can may be come up with an idea.
door Deel
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Most cells can be replaced every 4-5 years. Get out the install manual, it should tell you how to tear down and get a new cell that matches your model, easy fix. Get a zinc anode to help with corrosion problem, it attracts the Na ions instead of all metal parts, easy to install on ladder or plumbing and will help prolong your cell...35 years in pool biz
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
Great idea about using a sacrificial zinc. I will be getting one for myself soon thanks.
door Deel
Cyndi - are you a sailor by chance? This is how they save ships ;-)
door Deel
Hi!
I am also looking for a solution. Take a look at this:
http://www.philipdoolittle.com/2018/03/s...
I have 2 dead cells that I will open soon. With 2 may be I will get enough good plates to make one. My main concern is what material should I use if I have to rebuild a conneting post and how to fix it to the plate?
Richard
2 opmerkingen:
Hi Richard,
The link domain appears to be dead.
Do you have any info and how did you go with rebuild.
Likewise I have bits but not yet sure how to connect. Spot Weld?
Brett
door Deel
considering this myself, looking to source metal plates
desmetde@gmail.........com
door Deel
Voeg je antwoord toe
Daniel Rudewig zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 40
Altijd: 9,575
