Ga door naar hoofdinhoud
Released April, 2014. CPU - Quad-core 2.3 GHz Krait 400, GPU - Adreno 330. Display - IPS LCD, 16M colors, 1080 x 1920 pixels, 5.2 inches. Internal memory - 16 GB, 3 GB RAM. Android OS, v4.4.2 (KitKat). D6502, D6503, D6543
20 Vragen Bekijk alle
Xperia Z2 Wont turn on
I recently replaced the LCD screen and after putting it back together it doesn't turn on when the battery is connected. When i disconnect the battery cable the screen lights up and the battery icon shows up. When i plug it back in the LED light flashes three times and nothing happens.
Is dit een goede vraag?
Score 10
Voeg een opmerking toe
8 Antwoorden
Is this whilst plugged into a power source? Was the battery disconnected before the repair?
Was dit antwoord nuttig?
1 Opmerking:
Yes...and yes
door
Same problem. Didn't leave the battery connected when I did the job, no. Any solutions?
1 Opmerking:
Same Issue for me too, would be interested if anyone has a solution.
door
Also having this problem. Was all working fine until I disconnected the battery to replace it. :/ Now it will look like it is charging with the red LED, but not actually turn on :/
anyone found solution for this?
replace the battery work 100%
2 opmerkingen:
I just replace my battery as still not working..Dont waste your money
door
I have the same problem, i was thinking of a battery reseat
door
I just replace my battery too. Not working. Dont waste your money. Buy new one.
http://forum.xda-developers.com/xperia-z...
The flex cable connector is not fully seated. It worked out.
Voeg je antwoord toe
Dylon Browne zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 7,263
