Ga door naar hoofdinhoud
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
Why are my fans so noisy
The fans run very loud all of the time.
Is dit een goede vraag?
Score 1
1 Opmerking
Have you done any interior work?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
When u say "all of the time" im gonna assume that they're running on high even when you're Idle. First things first, I would make sure that there are no background processes using up your CPU's resources. if thats not the case and your machine is in a properly ventilated area, then I would have a look and clean up the fans with compressed air. If this doesn't remedy the situation, then I would replace the fans. Power Mac G5 Bottom Right Cooling Fan Unit Replacement
Power Mac G5 Top Left Cooling Fan Unit Replacement
Power Mac G5 Bottom Right Cooling Fan Unit Afbeelding
Handleiding
Moeilijkheid:
Eenvoudig
5 - 10 minutes
Power Mac G5 Top Left Cooling Fan Unit Afbeelding
Handleiding
Moeilijkheid:
Eenvoudig
5 - 10 minutes
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
I also recommend you install a Fan and Temp monitoring utility like SMC Fan Control.
door
Maj. - wait for more info before recommendations, please.
door
I have iStat Widget that monitors temp and fan RPM. Most of the areas are over 100 Degrees. Monday I can get an exact reading of the interior and let you know. I guess it could be overheating and not bad fans. Fan replacement looks fairly straight forward, but heat sinks I would think are a different story.
Thanks,
Gerry
Voeg je antwoord toe
Gerry Beane zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 3,553
