Ga door naar hoofdinhoud
Power Mac G5 Top Left Cooling Fan Unit Replacement
    1. Power Mac G5 Top Left Cooling Fan Unit Replacement, Side Panel: stap 1, afbeelding 1 van 1
      • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
      • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
      Vraag FixBot
      Voeg opmerking toe
    2. Power Mac G5 Top Left Cooling Fan Unit Replacement: stap 2, afbeelding 1 van 1
      • Remove all the cables, including the power cables before opening the unit.
      Vraag FixBot
      Voeg opmerking toe
    3. Power Mac G5 Top Left Cooling Fan Unit Replacement: stap 3, afbeelding 1 van 2 Power Mac G5 Top Left Cooling Fan Unit Replacement: stap 3, afbeelding 2 van 2
      • Lift the tab to unlock the side panel.
      • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
      Vraag FixBot
      Voeg opmerking toe
    4. Power Mac G5 Top Left Cooling Fan Unit Replacement: stap 4, afbeelding 1 van 3 Power Mac G5 Top Left Cooling Fan Unit Replacement: stap 4, afbeelding 2 van 3 Power Mac G5 Top Left Cooling Fan Unit Replacement: stap 4, afbeelding 3 van 3
      • Remove the air deflector (the clear plastic cover) by pulling on the handle.
      Vraag FixBot
      Voeg opmerking toe
    1. Power Mac G5 Top Left Cooling Fan Unit Replacement, Top Left Cooling Fan Unit: stap 5, afbeelding 1 van 1
      • Locate the top left cooling fan unit.
      Vraag FixBot
      Voeg opmerking toe
    2. Power Mac G5 Top Left Cooling Fan Unit Replacement: stap 6, afbeelding 1 van 1
      • Pull the fan straight out from its slot. You will need to remove two cables from the motherboard.
      • It may be easier to reach the cables if you remove the PCI guide (next to the fan unit) first.
      Vraag FixBot
      Voeg opmerking toe
    3. Power Mac G5 Top Left Cooling Fan Unit Replacement: stap 7, afbeelding 1 van 1
      • After pulling out the fan unit, the area should look like this.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
20 andere personen hebben deze handleiding voltooid.
Salvador Aguilar
2.550 Reputatie
3 handleidingen geschreven
Cal Poly, Team 5-8, Forte Winter 2010 Lid van Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Leden
66 handleidingen geschreven
1Gids Commentaar
Actually you do need to remove the plastic air deflector, as the fan in question is behind it.
Tim downing - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 68
Altijd: 20,038
