Ga door naar hoofdinhoud
Power Mac G5 Bottom Right Cooling Fan Unit Replacement
    1. Power Mac G5 Bottom Right Cooling Fan Unit Replacement, Side Panel: stap 1, afbeelding 1 van 1
      • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
      • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
      Vraag FixBot
      Voeg opmerking toe
    2. Power Mac G5 Bottom Right Cooling Fan Unit Replacement: stap 2, afbeelding 1 van 1
      • Remove all the cables, including the power cables before opening the unit.
      Vraag FixBot
      Voeg opmerking toe
    3. Power Mac G5 Bottom Right Cooling Fan Unit Replacement: stap 3, afbeelding 1 van 2 Power Mac G5 Bottom Right Cooling Fan Unit Replacement: stap 3, afbeelding 2 van 2
      • Lift the tab to unlock the side panel.
      • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
      Vraag FixBot
      Voeg opmerking toe
    4. Power Mac G5 Bottom Right Cooling Fan Unit Replacement: stap 4, afbeelding 1 van 3 Power Mac G5 Bottom Right Cooling Fan Unit Replacement: stap 4, afbeelding 2 van 3 Power Mac G5 Bottom Right Cooling Fan Unit Replacement: stap 4, afbeelding 3 van 3
      • Remove the air deflector (the clear plastic cover) by pulling on the handle.
      Vraag FixBot
      Voeg opmerking toe
    1. Power Mac G5 Bottom Right Cooling Fan Unit Replacement, Bottom Right Cooling Fan Unit: stap 5, afbeelding 1 van 2 Power Mac G5 Bottom Right Cooling Fan Unit Replacement, Bottom Right Cooling Fan Unit: stap 5, afbeelding 2 van 2
      • The cooling fan unit is located on the bottom right of the Apple G5 Desktop.
      Vraag FixBot
      Voeg opmerking toe
    2. Power Mac G5 Bottom Right Cooling Fan Unit Replacement: stap 6, afbeelding 1 van 2 Power Mac G5 Bottom Right Cooling Fan Unit Replacement: stap 6, afbeelding 2 van 2
      • Remove the G5 metal cover from the processing/cooling unit of the computer. NOTE: Apple inserted a rather fragile plastic pin that inserts through the top divider shield and clips into a tab on the hidden ledge of this CPU shield. Removing this pin, certainly voided Mac's warranty - but more appropriate for now, voids most after-market insurance plans. A replacement pin (new) is hard to get ahold of, and very few are talented and patient enough to remove this pin without damaging it. Just something to keep in mind. If you have no warranty any longer or don't care, please continue...
      • Pull the metal plate to the left and outward to remove the plate from the processing/cooling unit.
      Vraag FixBot
      Voeg opmerking toe
    3. Power Mac G5 Bottom Right Cooling Fan Unit Replacement: stap 7, afbeelding 1 van 1
      • Locate the bottom right fan.
      Vraag FixBot
      Voeg opmerking toe
    4. Power Mac G5 Bottom Right Cooling Fan Unit Replacement: stap 8, afbeelding 1 van 1
      • Unplug the fan's power cable from the upper rightmost corner of the motherboard (connection J45). If there is a video card in place, carefully pull the cable plug down between the back edge of the video card and the motherboard. Note, the photo shows the unplugged cable and the area it plugs into outlined in yellow. No video card is shown in this photo.
      Vraag FixBot
      Voeg opmerking toe
    5. Power Mac G5 Bottom Right Cooling Fan Unit Replacement: stap 9, afbeelding 1 van 2 Power Mac G5 Bottom Right Cooling Fan Unit Replacement: stap 9, afbeelding 2 van 2
      • Locate the tabs on the fan unit.
      • While pushing in on the tabs, highlighted in yellow, pull the fan back towards the cooling unit.
      Vraag FixBot
      Voeg opmerking toe
    6. Power Mac G5 Bottom Right Cooling Fan Unit Replacement: stap 10, afbeelding 1 van 2 Power Mac G5 Bottom Right Cooling Fan Unit Replacement: stap 10, afbeelding 2 van 2
      • After the latches are out, pull the fan out.
      Vraag FixBot
      Voeg opmerking toe
    7. Power Mac G5 Bottom Right Cooling Fan Unit Replacement: stap 11, afbeelding 1 van 1
      • After removal of the bottom right fan the space should look like this.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
33 andere personen hebben deze handleiding voltooid.
Adam
873 Reputatie
3 handleidingen geschreven
Cal Poly, Team 5-8, Forte Winter 2010 Lid van Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Leden
41 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 31
Afgelopen 30 dagen: 100
Altijd: 35,489
