Ga door naar hoofdinhoud
A widescreen 15.4" notebook computer by Compaq released May 2006.
4 Vragen Bekijk alle
computer doesn't start up
It wont start up. Only see a blinking cursor on a black screen. By pressing F10 while booting up I enter the setup. Here I see for the diagnose the options for selftest harddrive. Everything seems ok. I try to reinstall the windows xp by cd. The cd starts up but then the computer says there is no harddrive. What can go wrong?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
De Cuyper, sounds like a bad hard drive to me. Try to see if the hard drive shows up in the BIOS. Make sure it is properly connected. Most likely so you will need a new hard drive.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
In the bios I can check if there should be a problem with my HD. This seems to be ok. But when trying to install the windows XP the computer sais there is no HD. I connected the hd extern and I can see the HD is ok.
door
Voeg je antwoord toe
De Cuyper zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 457
