Ga door naar hoofdinhoud
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 Vragen Bekijk alle
My iPod boots up, syncs, and plays, but will not output sound.
I prematurely replaced the headphone jack thinking that was the problem - which didn't work - and then realized it also won't output through the docking jack to my stereo. Yes, I dropped it.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
sounds not good.
i answered to a similar problem a few days ago.
i qoute myself ;-)
a common problem are shot capacitors on the logicboard (c145 & c146). you can see them in step 8 of the logic board guide. the two orange parts are sometimes defective/shot/burned. they are 220µF capacitors and if they are "bad" they could look like this:
it could also be a problem with the P5021C-TDF - this part is the black one, left from the burned piece on the image above
the solderings of this chip failed on many 5g iPod's in less than a year - if you want to read more about it: CLICK here
if you open your iPod (enough to reach the black chip i mentioned) - and play some music - try to press slightly with your finger in the back thing - now you should hear the music
Was dit antwoord nuttig?
Score 3
4 opmerkingen:
Great Answer. ++++ I know who to go to for the stumpers. LOL
door
markus weiher - Hi I realise that this is a very old post but seeing as you seem to have extensive knowledge on these Ipods, I was wondering if you might know where I can get a circuit schematic for ther Ipod 5th Gen video. Thanks and I’ll look at those two caps and chip that you mention to see if I can fix mine. I have sound when inb the dock but nothing them the headphone port.
door
@pedro147 markus weiher hasn't been on here since 2011. Schematics are not available for this iPod. Replace your headphone jack flex then re-evaluate
door
@oldturkey03 thanks I thought that it was worth a try :) I have ordered the flex and I'll test the two caps for shorts later and see. If the flex doesn't fix it I'll replace the caps.
door
Voeg je antwoord toe
ryanelting zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 1,526
